Old May 21, 2015 | 05:51 AM
RED DOG's Avatar
RED DOG
Default Re: Problem with the small wings on metal booth
Hello Don, Those small wings are called tonneau side flaps and your problem is with the tonneau side flap cable(s). Follow the routing of the cables and right near where the cable(s) connect to the tonneau side flap(s) there is a guide pulley. See if the cable(s) might possibly have come off their pulley . . . not likely because the pulley has a little cover (removable) that is supposed to keep the cable from coming off the pulley but check that anyway). If the cables are routed correctly then the inner cables ares seizing up. Lubing should fix the problem unless the inner cable has become frayed. If lubing the cables doesn't help (make sure you're getting plenty of lube inside the cable between the inner and outer cable and follow the cable to up near the hydraulic cylinder to lube BOTH ends of the cable), your only option would be to replace the cables. The part number for the cable(s) is:
05140962AA
You'll find some additional information in this thread . . .
https://www.crossfireforum.org/forum...tml#post676188
The usual problem with the cable(s) is that one of the little barrel ends breaks off . . .
Good luck getting it fixed and please let us know what you did and how you fixed it.
