Thread: AFRs Help
Old May 21, 2015 | 12:00 PM
grip grip's Avatar
grip grip
Default Re: AFRs Help
Originally Posted by austinbarrylee
Please help. I can't get my AFRs dial in correctly. I have 62mm Karman. Upgraded fuel injectors, pump, filter, reg. I have DCAI with xtreme filters. Can someone please tell me what to set my AEM regulatory gauge at. Right I'm at 60. AFRs are all over the board. Cruising range from 15.1-15.5. WOT is at 11.5. All these numbers are according to my AEM gauge which has a new sensor on it but is old. I don't know if the gauge is bad. I do have datalog I can share from Eurocharged program. Thanks.
Please research open loop and closed loop. In closed loop (cruising around town) your car will try to stay at stoich, which is 14.7. It should constantly bounce to just above and just below that amount. It won't just stay at 14.7.
Once you floor it and it goes into open loop, you should see 11's. Your 11.5 is good.
