AFRs Help
Old May 21, 2015 | 11:56 AM
austinbarrylee's Avatar
Default AFRs Help
Please help. I can't get my AFRs dial in correctly. I have 62mm Karman. Upgraded fuel injectors, pump, filter, reg. I have DCAI with xtreme filters. Can someone please tell me what to set my AEM regulatory gauge at. Right I'm at 60. AFRs are all over the board. Cruising range from 15.1-15.5. WOT is at 11.5. All these numbers are according to my AEM gauge which has a new sensor on it but is old. I don't know if the gauge is bad. I do have datalog I can share from Eurocharged program. Thanks.
Old May 21, 2015 | 12:00 PM
grip grip's Avatar
Default Re: AFRs Help
Please research open loop and closed loop. In closed loop (cruising around town) your car will try to stay at stoich, which is 14.7. It should constantly bounce to just above and just below that amount. It won't just stay at 14.7.
Once you floor it and it goes into open loop, you should see 11's. Your 11.5 is good.
Old May 21, 2015 | 12:06 PM
Thanks grip grip for help. I wish I could take a video of the gauge when driving but camera phone will not pick out lights the gauge. What do u recommend taking to dyno and mess with the pressure gauge there. I'm set at 60. Should I go higher or lower. I was told datalog from ob2 can't read AFRS
Old May 21, 2015 | 12:08 PM
Do u know about datalogs. I could email you my logs and u can look at.
Nov 11, 2015 05:22 AM
Jul 29, 2015 06:13 PM
Zoodust
Jul 16, 2015 06:17 PM
JesseJamessrt6
Nov 30, 2013 11:40 PM
velociabstract
Feb 25, 2012 12:54 PM
