Old May 26, 2015 | 05:35 PM
Guran's Avatar
Guran
Default Re: Who is running stacked pulleys?
Originally Posted by Sweet2002
I have the Euro. 65mm SC pulley. Not many mods left that give a decent return for the price. If I added a 178mm crank pulley and pulley saver kit I might get the best return.
Another option would b to raise the shift points to 6500rpm. That would get the rollers spinning at a higher rpm and perhaps give good results keeping the revs up after shifts.
The pulley could be done with the stock injectors and the Kenne-bell boost-a-pump. It works on the Cobra motors running over 1 bar of boost. THX
I still would like to know what supporting mods you guys with the stack are running and the boost you attain.
I have 64.7 mm s/c pulley and 186 mm crank pulley. Solid aluminum crank pulley.
SL55 Fuel pump. 985 cc/3.8 bar fuel injectors. E85.
On the Video i run 70.65 s/c pulley, 186 mm crank pulley and gasoline.
And a leaking Iintercooler.
https://www.crossfireforum.org/forum...ale-3-3-a.html
