Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
May 27, 2015 | 10:32 AM
838
permalink
crymar
Jun 2011
103
Arlington, VA
Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Quote:
zip439
Did you remove the pin and spring pictured in post 829? A new ignition lock unit is not a fix that will last very long. I'm a bit confused by your post. Sorry.
No, I didn't remove the pin. I installed a new ignition lock unit. From what I've read on this thread, it seems that it's the pin that causes all the problems. I wanted to see if someone cold explain exactly how the pin functions and how it eventually causes the key to stick. The original ignition lock unit in my 2004 coupe lasted more than 10 years before it became a little sticky, but not to the point where I couldn't drive the car. It was just getting annoying, so this was a preemptive repair. If this new one lasts ten more I'll be happy. The fact the the pin pops out at the steering column side of the clamp when installed indicates that it's also used as a positioning mechanism. In any case, I wanted to know more about this mechanism.
crymar
View Public Profile
Send a private message to crymar
Find all posts by crymar
