Old May 27, 2015 | 01:56 PM
Mrmiata's Avatar
Mrmiata
Default re: How to disable the light out indicator
Originally Posted by Travish
I found this about the flasher location.
Turning Signal Flasher is under the hood in the drivers side fuse box. When you remove the cover from the fuse box you will see the fuses but no relays / flashers. You must then remove a second cover. The snaps are along the side of the box.
Is there a electronic instead of thermal flasher to correct the fast blinkers? I have that in the Buick so the turn signals flash normal.
I added LED's to my coupe.. and researched.. The Miata has a control you can add a resistor to (lucky them).. ours look to tie into the lighting control module.. and then it would be best guess as to whether you could do anything with it.
Would love to find out otherwise "there is a flasher unit"..
