Old May 27, 2015 | 05:32 PM
  #447 (permalink)
SparkieSRT6's Avatar
SparkieSRT6
SSB SRT6 405hp/401Tq
Default Re: 62mm SRT6 Pulley Available Now
Originally Posted by syfi
Seeing as how your a/c compressor is spinning the same rpm, I'd say yes. They are running off the same belt!
Completely inaccurate!!
The rpm will depend on the diameter of the pulleys, if they are the same diameter they will rotate at the same rpm.
So what diameters are we talking about?
Under normal conditions the SC bearing will not be rotating at all as it will be locked up when the SC kicks in. So we can say that the AC bearing sees a harder set of conditions, side loads and higher rpm.
Yes. I no longer have my Crossfire to compare the pulley sizes.
