Old May 29, 2015 | 09:17 AM
  #840 (permalink)
crymar's Avatar
crymar
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by KDW4Him
I don't think there has been a definite explanation as to what parts do what and why. We are not talking about removing the "pin" that "pops out." We are talking about removing the internal pin and spring. Do you have your old assembly? Did you remove the cover plate and look inside?
Sorry, I didn't explain as completely as I intended to. I was wondering if the external pin (the one that pops out at the inside of the clamp band after the unit is installed) is used as a positioning mechanism only, or if it's somehow connected to the internal mechanism that causes the problem. Since I still have the old unit, I'll take it apart and do some exploring. Should have thought about that before posting! Also, once I get the internal spring out I'll have a modified one hand in case the new one goes bad.
