Old Jun 11, 2015 | 08:16 AM
  #861 (permalink)
crysireland's Avatar
crysireland
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
I assume that you are aware that the cargo divider in the trunk must be in the position where you have little trunk space left before you can put the top down ?
This divider has a rod at the top that snaps into sockets on the left and right side.
On the drivers side of this socket there is a switch that tells the top control module that the divider is in the correct position.
This switch is kinda hard to see. There is a plastic slider that actuates the switch when you have released the top from the windshield frame.
This one is a bit of a PITA : it is INSIDE the trunk latch assembly. You would have to remove the plastic cover in the trunk lid, then using torx and 10mm wrenches, remove the latch assembly to inspect / meter this switch.
I do know about the divider and that its imperative its perfectly in place. I didn't know thats all you meant. Gotcha on that. The rest of it idve eventually figured out to check through this forum and Google but you saved me do much time and im grateful. Cant wait to get home and check
