Old Jun 13, 2015 | 08:47 AM
onehundred80
Default Re: Selling Parts off off parts car
Originally Posted by amatxcrossfire
I am in need of the scream module and vacuum supply pump/ central locking system
SKREEM modules can be had on eBay for about $50, they are called Door Lock modules there often, thery have to be programmed with the VIN.
The Air/Vac pump is a different beast and are around $400/$500 used on eBay (click). If you have had trouble with water then you should buy a used one WITH the plugs that were cut off with the pump. Water corrodes these plugs and a good pump with your old plugs may not work. Getting the plugs on their own is nearly impossible.
