Re: Selling Parts off off parts car
onehundred80
SKREEM modules can be had on eBay for about $50, they are called Door Lock modules there often, thery have to be programmed with the VIN.
The Air/Vac pump is a different beast and are around $400/$500 used on eBay (click). If you have had trouble with water then you should buy a used one WITH the plugs that were cut off with the pump. Water corrodes these plugs and a good pump with your old plugs may not work. Getting the plugs on their own is nearly impossible.
thanks for the info! do you know what the other little box in the trunk is and what it does, i thought it was the screem module? is that right? just found out its the alarm module
