Old Jun 27, 2015 | 10:20 PM
  #47 (permalink)
Black_X_Fire_04's Avatar
Black_X_Fire_04
Default Re: '04 Coupe Liftgate lock failure
Originally Posted by jd007
Im having the same problem,I hear the buzzing sound from the trunk actuator but truck remains unlocked front doors lock fine using the key..have you resolved this problem? I could use your insight..
Yes I have resolved the issue! It was rather simple. I removed the line by slicing it with a sharp blade and peeling it off the barbed fittings. After I removed the interior panels. I scoured the Mercedes forum looking for the actual tube used (in bulk) because there was no way I was paying 200 plus dollars for the cheap plastic tube from the dealer. You can find the tube here: http://www.autohausaz.com. Search for part number: 0001581435. I ordered 3 meters for under 10 bucks, right on! All you will need to install is a heat gun and some time. Reply if you have any further questions. I'll check to see if I have any photos of the tear down. Cheers!
