Old Jul 10, 2015 | 07:23 AM
onehundred80
Default Re: New brakes grinding on new rotors
Originally Posted by Roty135
Alright thanks for the quick replys...the grinding was present before doing any work. And remains after bearings rotors and brakes. As far as other axle goes...no its def this one because when I jack it up and spin it it catches on the brake...as far as before pumping the brake...it spins more freely before pressing brakes...seems like you might know something about this? If so im all ears. Ive checked all my work two or three times so im lost. As far as the wobble I have broken it down taken the hub off inspected the bearings and cant seem to find any issues other than when I put the brand new rotor on and look at it while it spins it appears to wobble . It's driving me nuts :l
You said in another post that you had hit a curb and damaged the front suspension. I think you have bent the wheel spindle.
You should have mentioned all of what happened before you did the brakes, as some of us do not have a crystal ball.
