Help TPS nitrous Question
Lot of threads here on which wire to tap into for your 0-5 volt signal of the throttle body.
But they all start with a request for which wire to use & end with I found or figured it out, with out telling us which wire it was?
I know how to calibrate the throttle body. but I can not seem to figure out which wire to use.
I found the purple has 5 volts but it is constant if the throttle body is closed or open.
anyone remember which colour wire they used when they did their nitrous install?
Barry
