Old Jul 11, 2015 | 05:21 PM
GraphiteGhost
Default Re: Issue with OEM radio sound cutting out . . .
Originally Posted by Ian69
Have just checked and can feel a flow of out of the pipe and here the fan running
It is a gentle flow not a blast
Is this sufficient to cool it?
Should be IF the car A/C fan isn't on (you could be feeling the air exhausting out the end where it exits the car). If it is blowing with the car A/C fan off then it is blowing enough. So, something may be causing a thermal shutdown, is there any dirt/sand/debris around the amp? If not, is there a bad impedance mismatch on the output to the speakers (ohm the coils from the plug at the amp going to the speakers not the amp side, the values/pinouts are somewhere in the service manual available for download). Is there any specs for how much current the amp draws? Can you measure that value to compare it?
