Old Jul 17, 2015 | 12:01 PM
latemodel21's Avatar
latemodel21
Default Re: Suspicious water pump.
Originally Posted by Tp'sfury
Thanks for the helpful info guys. I appreciate it. Ill look up those part numbers and see what's out there. As far as brands go and I ALREADY LEARNED THIS LESSON with the CPS, what are acceptable brands to work with. Please let me know which ones were NOT a good choice as well. Thank you ALL again. This forum is fueled by AWESOME folks!
If you are thinking you might be installing a belt wrap kit down the road, you will want to make sure that the pump you are getting has the "ear" (area outlined in red in attached pic) in its casting. This pump (for the srt6, slk32 and c32) can be found both with and without this "ear". Both pumps work fine in a stock set-up, but both Needswings' and my Belt wrap kit rely on this ear for updating the pulley configuration.
Cheers,
Chris
