Old Jul 24, 2015 | 02:38 PM
Sweet2002's Avatar
Default Re: any1 have pic of fuel reg installed by pump?
Originally Posted by rmcdaniel12
I dont have the bottom hose going back to the tank. It goes from the outlet of the filter to the regulator. My set up is: tank hose to bottom of pump, top of pump to top inlet of filter, bottom outlet of filter to inlet of AEM regulator, outlet of AEM regulator to fuel rail line.
Thanks, I guess once I or a shop gets under there it will fall into place. Did you use the .100" piece that came in the regulator or change it? It controls how much fuel can flow. Thx.
PS: one of the 3 fittings Rob supplied is larger than the other 2, where does that go on the AEM, the right side?
Rod, your description helped a lot, thanks. I am hoping to have the pulleys, wideband and fuel pump/filter/regulator all installed this coming tuesday, Mark
