Old Jul 29, 2015 | 08:21 PM
onehundred80
Default Re: Stuck ignition switch
Originally Posted by blacktouring
While I appreciate the excellent tips for switch replacement, it seems to me that it is worthwhile to understand the basis for the failure first. After all, it can happen again. I have seen no comments on this subject, but no doubt some of you took apart your bad switch to discover the answer. You may see what is wrong with it. If you know the answer, please post your knowledge and the possible solution. Thanks
blacktouring
I'd say that a steel part under spring pressure constantly moving up and down in an aluminum alloy part is ripe for failure.
Later parts were sent out without this seemingly useless assembly, no doubt a product of over engineering. No lubrication was visible in mine when I fixed it prior to failure.
