Old Jul 31, 2015 | 03:17 PM
KDW4Him's Avatar
KDW4Him
Default Re: Ignition key gets stuck / throttle cable module
From the book..... "The ignition lock control cable attached to the Shift Lever Assembly prevents the driver from removing the ignition key if the selector lever is not in the Park position."
I have done two of the sticky key mods and the connector just unplugged then reconnected fine.
Could the other end be the problem?
If it just came loose did it break off the slider the ign moves so it can no longer move the cable?
