Old Aug 8, 2015 | 07:05 AM
ala_xfire
Default Re: Am I Missing Something?
True, if the belt is the correct length.
And the tensioner is not seized up or has a broken spring.
Seizure is possible, I see rust on the water pump shaft and signs of mild corrosion on the engine block in the picture.
Also make sure the belt has no signs of oil contamination.
