What is the unit under the headlight?
I have a UK n/a xf, I have just found a broken negative wire on that unit. It is bolted with 2 bolts under the drivers side headlight, it has 2 wires going to it and one pipe coming from the 2 small canisters and one pipe going to the engine. Can this be fixed as the pole has corroded or is it a new unit? What is the unit called?
