What is the unit under the headlight?
Aug 10, 2015 | 04:33 PM
permalink
onehundred80
Apr 2006
25,432
648
Ontario
Re: What is the unit under the headlight?
Quote:
ala_xfire
The pump has an extension on the motor end cap with 2 round brass pins that the harness connects to. If the pins are gone, then you will need a replacement pump.
0 392 020 029
Engine Auxiliary Water Pump-Bosch 0 392 020 029 fits 96-03 Mercedes E320
Is it possible that the cap can come off, have wires attached to the contacts inside, then have the wire protrude from the cap which is resealed by silicone and have the ends of the new wires attached to the existing plug on the harness?
Maybe the plug has to be cut off and have an insulated wire to wire connection
I'd sure hate to toss out a perfectly good pump if it is still working.
It may not look too pretty but whose looking anyway?
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
