Old Aug 29, 2015 | 08:27 AM
Billto's Avatar
Billto
Default Re: 722.6 Transmission
Rudy said that these transmissions run best when the fluid recommended by Mercedes is used. I would not use any other fluid because it said to be the best by its manufacturer or because it is cheaper or whatever. If you want to save a buck here or there get a beater.
I always recommend that if you buy a car from a forum member you should read his or her old posts and see if you agree with any maintenance that is written about.
Thank you for your input. I am going to use the Mopar if I can get it. Other than that I think I will work with my transmission guy on what to do. Thanks again, Bill T.
