Old Aug 30, 2015 | 11:08 AM
  #70 (permalink)
onehundred80
Default Re: Index of Crossfire problems and repairs
( that's the 2 round things in front of the battery )
I think they are normally open and should close when the temperature dial on the dash is turned to cold.
If the hose going to the firewall from the valve is hot then the valve is not working or the temp control for that valve on the dash is not working properly.
I'm told (in a GrayGhost post) that these valves cycle between open and closed faster or slower depending on the temperature setting, presumably totally shut in the cold position.
These valves cost about $45 used on eBay, which would put them over $500 at the dealers for new ones, just joking.
