Old Sep 1, 2015 | 06:26 AM
Mrmiata's Avatar
Mrmiata
Default Re: Huntings revs after TB work...suspect Y pipe connection?
Originally Posted by minimayhem
If I knew the answer to that question I wouldnt be asking how many should be attached
When removing I didnt see the hose connection closest to the engine block. I did connect it however as it would be mighty strange to have 2 pipes and 2 connectors with only one plugged in.
I'm wondering if the MAF sensor is faulty.
I hope that you swapped in the OEM maf sensor with the maf housing upgrade..
