I bought a set of 440cc inj's but it seems I already have 440's in the car! the ebay seller has a set of 550cc but they are the same part number as what I already bought from him, afraid I wasted $190. Still do the intake manifolds need to be removed to change the injectors? Squirrel what do those cost, Rob sell them? What to do! Sorry I see I need to have the intake removed and obtain gaskets.
My motor has 0280156072's and I bought 0280155968 both Bosch and what I bought is a drop in from a Volvo. Now I need to find a true set of 550cc inj's it seems.
If you use any injector other than Bosch then you may need a wiring harness adapters and want be able to use the factory injector retainer clips. No biggie not being able to use the retainer clips because the bolted down fuel rail want allow the injectors to blow out. Way back in June 2014 the kit of TTM 550 injectors,EV1-EV6 wiring harness and looped fuel rail cost me $800.00 Plus Shipping. Purchased from Bruce at TTM. With these injectors and most others you want be able to use your injector clips. 550 injectors will make your car run Pig Rich unless you have serious mods. If your determined to run 550's then quickly figure in a Dyno tune to scale them down when running basic mods or you may wash out the piston rings from the excess fuel washing away the cylinders vital oil film. Squirrel Crusher
