Old Sep 12, 2015 | 09:16 AM
onehundred80
Default Re: Spoiler microswitch part number
Originally Posted by Lockhouse
Hi,
Does anyone have the part number for a rear spoiler microswitch for a 2004 Roadster?
I've found the microswitch online for 2007-2008 models here and just wanted to check in the absence of the 2004 being listed whether it's compatible.
Thank you
If you have access to the switch you should be able to get the makers name and part number from it. This part will be an off the shelf item, Chrysler would not make them specifically for the car. It should be a lot cheaper if you can. Micro switches are quite cheap.
