Old Sep 13, 2015 | 12:29 PM
onehundred80
Default Re: Electrical problems?
Originally Posted by nataliefs
Hi,
I am a new member and love my 2005. First car I ever really wanted to drive. (note: female, so if I don't explain everything correctly, I apologize). Unfortunately, the electrical systems is doing the following:
1. The driver side window will go down, but not up. Eventually, after many tries and many minutes later it works. I no longer use my driver side window in fear it won't go back up.
2. The ac/heater will change speeds and go hot in the driver's vent (middle console) while the passenger's side will continue to cool. If I change speed, or use recirculate....the problems of the hot/cold speed will start. Therefore I try only to use the on/off fan. However, it also does this on its own even if I haven't touched anything.
3. Left blinker is now going faster.....almost as fast as a hazard light...noise of blinker faster too. Eventually goes back to normal and next use goes faster again.
My car only has 45K miles...does anyone have a solution for the ghost in my machine?
I will be grateful for any help as I love my baby!
This should really not be in the New Member Intro forum.
Do you get the bulb out indicator lighting up when they flash quicker than normal? If so and even if it does not you may have a contact problem in a particular bulb socket, normally it is one of the front ones that have this problem.
