Bill F
This owner had the same issue. Here is what he found.
orbit398 orbit398 is offline
User Gallery
Default Re: code P0171 and P0174
Problem Solved
Figured I'd let others know what the problem was. Engine running lean and throwing the P0171 & P0174 codes due to small air leak. Only at idle would this symptoms appear. Ran great other wise. Searched and searched for leak using starter fluid on vacuum lines - found nothing. MAF sensor replacement didn't affect it. This rough engine at idle started soon after the oil change. Never put the two together.
On the oil cap is two triangles that one is to line up, I assume to indicate the cap is sufficiently tight. Well that was the issue. The triangles were lined up perfect. Problem was is the seal under the cap wasn't fulling mating with the surface (all the time) and was the source of the small air leak. The engine pulls a vacuum and was getting a little air from the oil cap. Had I tighten it like normal and not lined the triangles up, I would have never had then lean codes/engine running rough.
Local shop pressurized the engine via the intake with smoke of some sort and saw it coming out of the oil cap area. A new oil cap solved the problem. go figure.....
Thx for your i fo as well. Hope I can get it done without spending a fortune. Wish I had some of you DIY guys here.
