Old Sep 19, 2015 | 01:40 AM
  #58 (permalink)
jgreen's Avatar
jgreen
Default Re: Check Engine Light
Originally Posted by pioneer4x4
At time 377.2, notice how both bank 1 O2 sensors go to 0V, you might have a ground issue, or a short to ground issue. Just a guess, but I have seen an engine harness rub through and cause issues only under full access when it rubbed a certain way, but looked fine under the hood parked.
A weird ground issue may also explain the other sensor going weird. But as you mentioned Bluetooth OBD2 isn't perfect either.
Is there certain areas of the harness to inspect for wear?
