Re: N/A 74mm Throttle Body Upgrade Guide
Speedy4x4
Just a very little on oring, enough to hold it in place. Not a hefty bead all around.
Just a small amount on finger rubed on oring to make it sticky.
Done this many many times on various projects with 0 problem.
Didn't you 180 change the tb only and not the larger maf housing?
Yes I know oil can have a smell to it after long.
But this seemed more then usual.
My problem is not the seal, just improper air fuel ratio, at lower rpm.
I changed everything from TB to engine cover.
See here;
https://www.crossfireforum.org/forum...-version-2.pdf
Sounds like a vacuum leak somewhere to me. Or a torn gasket on the MAF to air box or TB to MAF.
