Old Oct 4, 2015 | 09:55 PM
  #84 (permalink)
onehundred80
Default Re: Mercedes Engine Cover Mods and 74 mm Throttle Body
Originally Posted by Zoonami
Is there a difference between engine cover 1120940004 and A1120901101? They look exactly the same and the 04 one matches the filter #. I can find a much better deal on the 0004 cover w/ filters than just the cover for 1101.
If there was no difference between the parts they would not have different part numbers.
If you are changing the cover then you should get the one that has the bigger filters or why bother.
Use #A 112 090 11 01 - main body.
Use
#A112 010 04 67- front piece.
Use
Filters, K&N's #33-2181, or OEM (paper) A 112 094 00 04
As described in post #1
