Thread: Alternator
Old Oct 5, 2015 | 06:34 PM
pizzaguy
Default Re: Altenator
The pulleys are different on the NA and the SRT as you know, also the connector to the alternator is different as well. The NA uses a Bosch alternator and the SRT uses a Valeo alternator hence the different connector. I believe the connector can be fudged to fit though.
Dave, my 07 SE has a Valeo as well. Which connector is different - I KNOW the battery stud looks a lot larger on the Bosch, but I can't tell from pictures if the low-current connector is the same, it is shaped the same on the outside, but I can't see the pins in it in the photo.
