Old Oct 16, 2015 | 08:09 PM
onehundred80
Default Re: possible pulley sound.. any suggestions
Originally Posted by waldig
Your torx bit is the correct thing and wont strip the bolt...Woody
A Torx bit is used on the SRT tensioner. A 17 mm socket is used on the Base and Limited, you use the cast in hexagon, that is why it is there.
If you use the Torx bit make sure it is the correct size, too small and you can kiss the screw head goodbye, it has been done here before.
You get a much better grip with the socket.
