Old Oct 20, 2015 | 06:00 PM
onehundred80
Default Re: Throttle Position Sensor?
Originally Posted by Brady517
So I ran the check engine light, and the crank position sensor, throttle position sensor, and an O2 sensor came up. Any idea where I can get a throttle sensor? My local auto parts stores don't carry them, and I have been unable to find one online for some reason. Thanks for the suggestions.
Like many of the parts on cars these days they are replaced as a unit, so no TPS spares.
The CPS has been found to have a weakness in the fit to the connector that goes to it, also make sure you have a Bosch CPS as other have caused problems. Make sure the connector is a tight fit on the CPS and there is no problem with the connector.
One problem an cause multiple codes to be written, solve one and the others are solved miraculously.
