Re: Engine Oil Emulsification
Fla_Xfire_SRT
Thanks James, I wonder if that's the kit Blackstone labs would use. I never realized there was a test kit for ethyleneglycol. Can I assume that there should be ZERO ethylene-glycol in the oil or is there a tolerance range? I saw the first test color indicated a ranged of 0 - 30.
Blackstone tested my oil and there was no EG in it, there should be none and if there was some found it should be fixed, small leaks become big leaks.
I had a GM engine ruined because of coolant leaks into the oil while the dealer denied anything was wrong.
