robby363
What brand of cps sensor did you use? With the engine running wiggle the cps connector plug to see if the engine stalls. If you use a cps other than the bosch sensor you can get a loose connection causing it to stall.
I used Import Direct from O'Reilly. I did the wiggle like you said and it did stall if I shook it too much.
