Re: Stalling
2004_
I used Import Direct from O'Reilly. I did the wiggle like you said and it did stall if I shook it too much.
I was having the same problem with the sensor I bought at Autozone. I bent the contact blades in the sensor so they were slightly uneven and it solved the problem. I did end up replacing it with this one
and kept the one from Autozone for a spare. The prongs on the generic cps are thinner then the bosch sensor so it doesn't make a tight connection.
