Old Jun 29, 2006 | 06:43 AM
Buck70's Avatar
Buck70
Default erratic temperature
Anyone know where the outside (air) temp sender is located on the '05 SRT6, so I can check the ground/connector etc.?
While driving around our display shows a swing of about 15* on a typical outing. Not a heat soak issue from the radiator, I'm talking about after it settles in, then wanders 10-15* colder than ambient, then back to normal.
Bad ground, bad sensor, loose connector, dunno??
Thanks,
DB
