onehundred80
Look at the areas where the cables attach to the body, battery etc. Look at the cables as well as these cables have been found to have corroded inside the insulation.
Look inside the box with the large fuses, this is beside the battery and look for bad contacts due to corrosion etc, not likely but who knows.
thanks 180 I will check all of these things and get back with you
