Old Oct 29, 2015 | 02:17 PM
  #43 (permalink)
onehundred80
Default Re: NEW Fog Light housings, LED based. Who would want this to happen?
Originally Posted by Mrmiata
Ever notice how our actual "light" is recessed in the housing? As far as dirt ... it's a sealed unit so not an issue. I don't see adjustment unless you fabricate it in. These are not coming out as "plug and play mountable".. You could just as easily purchase a 2 1/2" or 2 3/4" diameter fog light off the shelf and achieve the same result .. you will have to fab the mounting to secure it. I personally think the OEM blanks modified would make a better look.. and I'm sure you would still have to fabricate a support bracket to go that route .
I think you have missed the point, no glass or whatever to fill that rectangular space in makes the hole a funnel for all the crud that comes at it.
I have no need to worry though as I have a brand new set of spares on the shelf.
I have an idea to fix the OEM lights with new rectangular lenses. If one of mine goes I'll make one.
