Old Oct 31, 2015 | 12:14 PM
AlexParra's Avatar
AlexParra
Default No BRAKE LIGHTS - BAS/ESP signs on the dash + LIGHTS when I hit brake pedal
I've had this issue for a while now and I was able to resolve it temporarily after reading some posts here. I repositioned the brake light fuse in the fuse box on the left side of the driver due to apparent bad terminals. And that did the trick! But the BAS/ESP warning lights came back on and I've tried replacing the fuse, wiggle it, clean the connections and nothing.
I've also replaced the brake switch which was a popular solution. I've read something about installing a fuse bypass but wouldn't know where to star.
I would appreciate any input from someone who has experienced the same problem and has found a solution.
Thanks in advance!
