Old Nov 21, 2015 | 02:26 PM
kingdavid54's Avatar
kingdavid54
Default Re: Crossfire won't start, help!
[QUOTE=syfi;853099]Have you ever changed out the battery? Our cars are real quarky on the power flow.
Also have a look-see for burnt relays on the RCM. In particular the Fuel Pump Relay....
Attachment 36411[/QUO
When you engage the starter does it turn over at normal speed ? If it does you can eliminate the battery as a cause for no start, pm onehundred80 or ala_xfire and offer them a beer and a sub sandwich and they just might help you, good luck hope you get it fixed.PS : for whatever it's worth my
Humble opinion is that it is fuel related, quote; crank right up and ran for 5 seconds and then it quit, fuse, relay or fuel pump or fuel filter, eliminate what it is not and you will arrive at what it is, do your diagnostic work first and then spend your money on the correct part to change.
