First thing I would do is lie on the ground with your head just forward of the passenger side rear tire and have someone switch on the ignition to just before the engage starter position.
See if you can hear the fuel pump running.
If not then check fuses and the relay contacts for the fuel pump in the RCM.
( purty piktur courtesy of onehundred80 )
