Old Nov 29, 2015 | 01:09 PM
onehundred80
Default Re: Are my cats going out??
Originally Posted by Mattisonfam
The check valve has been replaced. I do notice the pump on at start up for about 30 seconds. Originally I wasn't too concerned about the p0410 code but I have to get emissions done and it won't work with check engine light on.. How much experience do you need to replace the relay? I'm not very car savvy... I'm sure there is a DIY on here that I'll come in contact with soon. Thanks for the input guys!
Go to this thread (CLICK) and take note of the #1 post in it, a poor ground can give the error code and it is the easiest and cheapest fix if it works.
If that does not work read the thread, your solution is in there somewhere.
