Old Dec 12, 2015 | 10:33 PM
8ighth Wonder's Avatar
8ighth Wonder
Default Re: Brake light relay
When the top cover of the fuse box is removed, you can see 2 rows of fuses, surrounded by another plastic cover. The second cover has detents at the front and both sides, press in on them and pull up on the cover from the front.
Once this cover is removed, you will see two black relays at the firewall.
The brake relay is the one toward the center of the car, the other relay is the locking relay.
Good description, I sent you the number to my shop in case you needed more info. If this doesn't fix your brake lights check the major fuses on the left hand side of the engine compartment, it's 3 fuses in the main power distribution location.
