Old Dec 16, 2015 | 07:58 PM
onehundred80
Default Re: How do I remove the entire Headlight Assembly/Headlamp(s)?
True, but personally I would not attempt it with my poor vision and fat fingers.
PLUS, it you remove the units, you can mount the HID ballasts on the frame under each headlight out of the way .....
The OP is only 25 years old so it should be no problem for him at all.
I did not consider taking the units out when I did it, I put a set in no problem and took them out later, easy peasy.
Taking the light units out has got to be real pain and that alone will take as long as putting HIDs in as in Max's How To post.
CLICK for the Max How To post.
The bulb assemblies have changed a little in design but the basic process is the same.
