boostmonkey
Looks good!
What is the correct spring tool that you used?
Thanks
Here's the correct Mercedes spring tool I used:
It's designed so you slip the 2 correct size cups into the spring then slip the long part up through the middle and do it up clamping the spring in position and simply pull it out and then the reverse to pop new one in, takes under 10 mins a corner
