Old Dec 17, 2015 | 04:24 PM
Mrmiata's Avatar
Mrmiata
Default Re: New Guy, Old problem
The security chip thingey in the key fob is not powered, so replacing the batteries would have no effect, however if it came loose inside the fob and migrated away from the sensor ring at the ignition switch, this could be the problem.
In your spare time, take the old fob apart and see if this is what happened.
https://www.crossfireforum.org/forum...ey-rebuild.pdf
Sounds on track.. I replaced my case.. and barely had the chip out of position and had the "start-die" syndrome.. realized my case wasn't quite closed as it was sitting on the chip "out of place".. fixed that and all was good. Buy the blank case before you do this.. I'm 3 for 3 on having to destroy the old one to get the guts out..
