Old Dec 21, 2015 | 03:30 PM
Craig73's Avatar
Craig73
Default Re: Crossfire won't start after collision
Originally Posted by UK-SRT6
Immobiliser unit (Skreem) has gone bad. You will need to replace with a brand new unit, used unit will not pair with ECU.
Ok that make some sense because the fault code says it's the skreem at fault but if I fit a brand new one would it need pairing to the ecu or is it just plug and play?
I have also read that if you leave the ignition on for one hour it will unlock it.
